HDM1 CABLE
Unbelievable1224
Message 8 of 8
I am trying to connect my 4K box with HDM1 cable but have not got a port with HDM1
only HDM2 and HDM3 how can I connect the box
7 REPLIES 7
Message 1 of 8
You should be able to connect the HDMI cable from the box to any available HDMI port on the TV.  With the box switched on, use the source button on the remote to switch between the HDMI display on the TV.
Message 2 of 8
Thanks for the update. I'll ask Karl to take another look at this for you.
Message 3 of 8
I have tried every port and it won’t work in 2,3 and 4 as I don’t have a HDM1 port.
thankyou
Message 4 of 8
I have tried connecting to other ports and nothing works
Message 5 of 8
have you tried connecting the box to one of these ports.
Unbelievable1224
Message 6 of 8
I haven’t got a HDM1 port on the TV only HDM2 and HDM3
Message 7 of 8
you should be able to connect the box to any available HDMI Port on the TV.
