New channels
on 03-09-2023 11:00 AM
Message 4 of 4
My Talktalk box constantly finds new channels that I cannot watch.
The box asks me to connect to the internet,whisch I already am. Any help?
Labels:
- Labels:
Settop box
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
3 REPLIES 3
on 03-09-2023 01:06 PM
Message 1 of 4
Thats what I have done.Thanks for clearing it up.
May have to ditch the box and go freeview.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-09-2023 11:53 AM
Message 2 of 4
Just to make it clear, this is a YouView limitation, not just a limitation with the TalkTalk box.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-09-2023 11:47 AM
Message 3 of 4
If you have a YouView box, this is a limitation with this as it cannot connect to these internet only channels. These are to be found in the 200+ range.
YouView boxes pick up channels from Freeview and these channels are available on Freeview play boxes and Smart TVs. Non smart TVs will also have these channels listed and receive the same warning messages as you get.
Unfortunately there is nothing you can do to get these via your box.
You could always hide these channels from view in the guide by using the yellow button and selecting them.
Whilst these will be hidden in the guide, they are not truly hidden as if you type the channel number the box will attempt to connect. Likewise if you scroll using the channel select up / down button, you will eventually hit them, but scrolling through the guide you won't see them, unless a new channel appears, when you can hide that one from view.
If there are normal Freeview channels you don't wish to see in the guide you can hide these too. If say you wish to hide the shopping channels, when in the guide use the blue button to select a category, then yellow to edit, then select the channels and done to hide them.
I find this declutters the guide.
Hope this helps.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
