on 05-09-2023 11:37 AM
Has anyone solved the problem with being unable to delete a scheduled series?
I am told that there are options for this but I can assure that there is no option on my pile of poo that is called a 4k TV box.
on 05-09-2023 12:04 PM
If you select the recording, is there an option to modify, that will then give an option to delete the scheduled recording?
