Problems with Talktalk tv plus box not recording on E4
Gnasher
Message 2 of 2
We like to record Married at first sight Australia on E4 however it nearly always fails to record. Occasionally other programmes on Channel 4 fail to record but E4 seems to fail almost all the time. I have tried resetting the box etc but to no avail…… any suggestions please.
1 REPLY 1
Message 1 of 2
Unfortunately this has been going on for well over a year now and YouView found the issue to be with the signal being transmitted by the transmitter owners.
There was supposed to be a fix being applied but there has been no sign of it.
Can you get the programme on 4s catch-up app? If so that's probably the way to go when a recording fails, but the downside is not being able to skip the adverts.
Others found that the +1 channels would record. Maybe set up a recording to see if this works, then delete the recording request on E4.
