Set top box making high pitched squeal and needs resetting daily
mrdbristol
Message 3 of 3
Huawei DN372T
After being turned off at night ( via the remote control ) , the next day the box is constantly making a high pitched squealing sound and needs 're-setting' using the physical button on the back before it works again.
It did not behave like this in the past, its been since last week.
Any help ?
Message 1 of 3
Hi @mrdbristol
Did the reset help ?
Message 2 of 3
It doesn't sound well, does it? Have you tried a maintenance mode reset at all?
https://community.talktalk.co.uk/t5/Articles/TV-Box-Maintenance-Reset/ta-p/1429347
