Signing in to channel 5
Stahill80
Message 2 of 2
I have a new 4x box . Trying to register channel 5. It came
up on my iPad but not on my tv
1 REPLY 1
Message 1 of 2
What actually happens?
Do you get a code on screen to input into the website to connect your account?
As you have it ok on your iPad I assume you have created a My5 account.
Do you get the option to input your email address and password?
If you can provide a bit more info we should be able to help.
