Sound problem
Dustyblues
Message 3 of 3
I’ve just set up my tv hub and the volume buttons are not working
Message 1 of 3
I posted this on your duplicate thread which you might like to try.
Have you sent the old one back yet?
If not then unpair the new one and then pair the box with the old remote.
https://community.talktalk.co.uk/t5/Articles/TalkTalk-Remote-Control-Guide/ta-p/2204370
Did that work?
If not try resetting the box to factory settings and hopefully it will then work.
nambuso-TT
Message 2 of 3
Hi there Dustyblues. I am very sorry to hear this. Just to confirm are you referring to the buttons of your remote or the Tv hub?
