on 25-07-2025 07:55 PM
My son's TV Youview box is not recording unless he leaves the TV on. He has learning disabilities so I wanted to know if anyone has any advice as to what I can do to help please?
on 28-07-2025 08:31 AM
Hi there @Rusty_2, thank you for reaching out. we are sorry to hear that, please do let us know how it goes and if you still require support with this.
-Fez.
on 26-07-2025 07:06 AM
They are available to buy from 29.99 on eBay if all else fails
on 25-07-2025 09:41 PM
Unfortunately these boxes are now reaching the end of their life.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings bit this will repair the hard drive if its possible.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box.
Hope it works and please let us know how you get on.
