Talk talk help and support
Daifishguard
Message 3 of 3
Having spent ages yesterday speaking to bots and getting nowhere, today I was passed on to an "expert'. He was fine and dealt very competently with my problem of being unable to record TV programmes. Named Aamun, he came on the line at 16.11 and very patiently attended to me until 16.58. Then the connection failed and my problem remains unsolved. What should I do next, TALKTALK
Message 1 of 3
Good morning,
How are you getting on?
Message 2 of 3
Which box do you have?
As you are asking about recording, I will assume you have a YouView box that previously recorded and recordings are now failing. If not, please note the new Hub does not record and the 4k box requires a usb stick.
Not sure what you have tried but have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but its the last thing to try
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new non recordable box.
Hope it works and please let us know how you get on.
