Talktalk TV Hub
Avocet1
Message 2 of 2
I understand the device doesn’t record, but is it possible to create a list of ‘bookmarked’ programmes I want to watch? I don’t want to have to carry out a search for programmes each time I switch it on.
1 REPLY 1
Message 1 of 2
You can add programmes and series to your watch list.
This only relates to programmes that are on catchup apps and only whilst they are available. If you use the Great app for example, shows disappear normally after a week.
If you have an existing YouView box, the watch list is the same as this box.
