Timer not changed
Wilko123
Message 3 of 3
Since the problem with the time not updating when clocks changed I can’t watch any of the recordings I already have
Linda w
Message 1 of 3
How are you getting on?
Message 2 of 3
These are two totally separate issues and the clock issue did not affect recordings, either old or new.
Hopefully your clock has now updated as fixes were deployed over the last two nights.
If you still have issues watching your recordings there are a few things to try, each step getting progressively deeper into the operating system and hardware in the box.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
Please note that if you are eligible for a new box, TalkTalk now only supply non-recordable ones., So it's best to try all alternatives if recording is important to you.
Hope it works and please let us know how you get on.
