Tv
Toonarmy11
Message 2 of 2
TV showing device is busy recording live twill be available when recordings are done I have no means to be able to record with my box hence can't view live TV ( help)
1 REPLY 1
Message 1 of 2
You will need a splitter and additional cables to hook both the TV and Box up so they each have an aerial feed. This way you watch TV and record on the box
Splitters and cables can be bought online or in some supermarkets.
