Humax not recording some tv programmes
cheekychappie
Message 2 of 2
My Humax recoder is sending "Failed to record" on some ITV programmes
It will record some ITV1,ITV2,ITV3 channels but wont allowCoronation Street" on ITV when i have set it on a series record
Any clues?
1 REPLY 1
Message 1 of 2
You say Humax box. Is this a YouView one?
If so then the following advice holds for this box too. If it's not a YouView box, you will need to search for your model number and maintenance mode hope this helps.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box.
Hope it works and please let us know how you get on.
