White spot
Kerry53
Message 4 of 4
When I turn on my TV a white spot appears. It is only when You View is connected. If I watch TV without the talk talk box there is no spot so it's not the TV but something to do with the you view box.
Any help appreciated
3 REPLIES 3
Message 1 of 4
Hi @Kerry53
What model of TV Box do you have ?  Is it connected via HDMI to the TV ?  If possible, can you post a picture of the TV showing the spot.
Message 2 of 4
Hi Kerry,
How are you getting on?
Message 3 of 4
Not seen this happen, but you could try another HDMI cable.
I doubt it's anything serious, but you could also try turning the box off for a few minutes and trying again.
Unless the box itself is showing any signs of failing such as recordings not playing, I wouldn't suggest any other resets at this stage.
