YOUVIEW box not working failed recordings and unable to watch previous recordings
Hughes80
Message 2 of 2
My YOUVIEW box is not recording, i am getting failed recordings and also i cannot watch previous recordings. What is talk talk going to do.
1 REPLY 1
Message 1 of 2
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box.
Hope it works and please let us know how you get on.
