talktalk 4k TV box
davealbert
Message 3 of 3
In the process of updating and am considering talktalk TV as currently using a Sky box. Does a normal HD TV work using a talktalk 4K box?
Thankyou
Message 1 of 3
The 4k box is really a streaming box with a tuner.
It has no loop through, so you will need to split your aerial cable to get a feed to the TV.
With one tuner, it will only record one channel (using your own usb stick) so if you wish to view another, splitting the cable for a feed to the TV is essential.
Message 2 of 3
A normal HDTV will work with the 4K TV box, provided it has HDMI input.
