on 08-04-2025 07:31 PM
i started a new contract and all i have is broadband 150, no phone, no extras and no talktalk tv which i was paying £5 a month for, question is i can still access all the apps ect via the talktalk box (which i thought was talktalktv) , anyone know why this is ? obviously not complaining but was just wondering if im missing something ? my old contract ended on the 7th so its only been one day, maybe it takes time ?? thanks .
09-04-2025 09:32 AM - edited 09-04-2025 09:33 AM
@dinks isn't that what I said when you rudely called me a bot for trying to help you?
You will now have to request a returns bag if one has not been sent.
on 09-04-2025 09:18 AM
Thanks Phil for clearing that up, much appreciated 👍
on 09-04-2025 08:13 AM
@Paulstewart The £5 you were paying was for the rental of the box as @fr8ys has mentioned, the box comes with pre-installed apps like Netflix etc. The £5 was not part of your Netflix subscription. TalkTalk TV only gives Freeview channels, and you have to purchase an ariel in order to watch that. If you don't return the box after cancelling the services, there will be possible charges as the equipment belongs to TalkTalk.
-Phili
on 08-04-2025 10:27 PM
Of course not!
on 08-04-2025 10:14 PM
are you a bot?
on 08-04-2025 09:54 PM
It's the generic name for the TV box, which gives access to channels and apps in one box.
Can't put it better than the AI result in a google search.
on 08-04-2025 09:45 PM
ok i get all that, ..... but what is talktalk TV?? and why was i being robbed for £5 a month ? someone out there must know ??!
on 08-04-2025 08:55 PM
Which box have you got? If it's a 4k or the non recording Hub box, you are effectively renting it so will get a replacement if it goes wrong. It's never yours to keep, which is why I said you may be asked to return it.
If it's an old YouView recordable box, it's doubtful they will ask for it back.
on 08-04-2025 08:47 PM
thanks for the swift reply, maybe i need to be a bit clearer in what im asking......what was i getting for £5 a month (talktalktv)?
i have canceled it now but seem to be getting everything still (apps ect) ? confused !
on 08-04-2025 08:03 PM
Your box will continue to work. If it breaks though it won't be replaced.
This though may depend on which box you have as if its the Hub for example, TalkTalk may ask for it back.
