Any truth talktalk going to 1.6gbps
sean2024
Message 7 of 7
Hi are the romours true talktalk will be selling 1.6gbps soon same as EE and also moving to Erro Wifi 7 routers ?
6 REPLIES 6
Message 1 of 7
TalkTalk plus is data only plan with speed of 900mbps, I haven't heard of any plans to increase that, but im sure if the capability is there there will be a plan in the future.
Message 2 of 7
OK. There is a product called TalkTalk Plus which is in its early stages. It is app based and currently provides speeds of 900 Mbps. I have asked the community manager whether this is likely to be enhanced further.
sean2024
Message 3 of 7
Talktalk plus im told it will be called ?
sean2024
Message 4 of 7
Openreach engineer told me they are going to supply 1.6 as now EE and Vodafone supply it
Message 5 of 7
Message 6 of 7
Woo, I love an unsubstantiated rumour! Where have you seen this? This isn't a support issue, so I have moved it to the Technology section.
