Router / mesh upgrade
CPeachey
Message 4 of 4
My router is At least 10 years old and I want to improve coverage at home with a mesh system.
what do I need and where to get it please?
3 REPLIES 3
Message 1 of 4
@Gliwmaeden2 Thank you very much for assisting and @CPeachey  please do let us know which option you would like. Thanks
Gliwmaeden2
Message 2 of 4
@CPeachey
What router do you currently have?
If it's c 10 years old, it's very likely not to have had any firmware updates for a long time.
Perhaps having it swapped out for a Sagemcom would be a good first step before considering upgrades to the package?
nambuso-TT
Message 3 of 4
Hello @CPeachey Thank you for reaching out. If you're interested in learning more about our Mesh system and the compatible packages, please check the link below.
Using eero's advanced features - TalkTalk Help & Support
If you're facing issues with your Wi-Fi coverage in certain areas of your home, consider upgrading to our Total Home Wi-Fi. This solution is designed to reach every room, ensuring reliable connectivity even through multiple floors or thick walls. With Total Home Wi-Fi, you can eliminate dead spots and stream your favorite shows anywhere in your home, whether you’re relaxing on the sofa or cozying up upstairs. For further information, please refer to the link below. Thank you.
About Total Home Wi-Fi - TalkTalk Help & Support
You might also consider upgrading to one of our higher speed packages, which offer full fiber connectivity. Thanks
