always a problem with the line
grahamh123
Message 31 of 31
So internet is really slow today - I am on fibre150 data only. When I run a speed test it gives me 38Mb down and 30Mb up to my device. Doesn't show a speed to my hub. When I do a line test it ALWAYS comes back with "we think you have a problem with your line" and then it says "we are working on it, please check back in a couple of day" When I check back in a couple of days the fault has been cleared - no message. A few days later it does it again. Last time I spent some time on the phone and was sent a new LAN cable, no difference. Starting to wonder why I went for fibre 150 as it seems no better.
30 REPLIES 30
Message 1 of 31
My apologies, I think I might have mis-read your last posts. Do you mean that your using powerline extenders not additional eeros?
Message 2 of 31
The eero sits on a table above the incoming fibre. Only thing near it is a ohone connected to the landline. One of the extenders is sat connected to the eero and the other is in the next room conected to a lan switch and from there via lans to study(desktop) and smart tv.
Desktop currently getting 90Mb.
Message 3 of 31
Thanks for confirming. Are the eeros not situated too close to any electrical devices that may be causing interference?
Message 4 of 31
Everything still fine thanks. No drop outs since installing new eero. Have to say tho that the wifi is not great. I know the eero is meant to be used as a mesh but all devices in use are within 15 - 20 feet of the router and I have two extenders hooked up. Not bad enough to want to pay for more eero's tho.
Message 5 of 31
Just checking back in to see if everything is still ok?
Message 6 of 31
OK thanks Graham 🙂
Message 7 of 31
So new eero arrived, Yodel useless - said they would deliver Friday - knew I would be away for w/e so asked them to deliver to neighbour; well they came Thursday and just left it on the step.
Anyway installed yesterday and all works fine. have noted the s/w version and will see how it goes after update when it happens. Have posted old eero back to Returns at talktalk.
Thanks for your help.
Message 8 of 31
You're Welcome 🙂
Message 9 of 31
thanks
Message 10 of 31
I've ordered the eero as a replacement for a faulty unit, and showing a final charge of £0.  Not sure why it triggered an automated email, but I've just checked your account, there is no change to your contract, and the eero6 I have ordered is showing with a final price of zero, so no charges are applied for this.
Message 11 of 31
Thanks for that but.......
just received the following email from yourselves
Account number:
1012684149
New package:
Fibre 150 Data Only
New package start date:
04 May 2023
One-off charges:
eero 6 Replacement : £89.00
Equipment:
eero 6 Replacement
The monthly price of broadband will rise in April each year by the rate of inflation plus 3.7%. New contracts from 1st Feb 2022 will receive this rise from April 2023. Please visit talktalk.co.uk/legal for more information.
Don't want a new contract. Present contract runs from January and does NOT include annual rise with inflation. I specifically chose that option - no incremental annual increase. Also charge of £89 for the eero??? And anyway why would I want to pay that when I can buy one from Amazon for less??
Message 12 of 31
I'll swap out the eero6. a replacement is on the way and we can see how this one behaves.
Message 13 of 31
Hi Debbie,
talktalk sent me the eero6 when I signed up in Jan. If I had bought it from Amazon I would already have sent it back. Did you see my post re dropout problems with eero6 after s/w update .13? Seems like quite a common problem according to posts on the eero site.
Message 14 of 31
Hi grahamh123
Can I just check, did we send you this eero or did you purchase this yourself?
Message 15 of 31
ok so its run fine with no more dropouts. It seems to me that the fault is withy the eero 6. Old router runs fine but slower. 64k question is how do I get the eero swapped out. Over the last 2 days I have spent some 3+ hours on the phone with tech help. All they want to do is get me to BUY more eero's for £6 per month or upgrade to fibre 500 - and therefore get eero's and pay more. Gave up this afternoon and refused to hold on the line any more. How do I get a faulty eero swapped out? It's not really supposed to be this difficult is it?
Message 16 of 31
OK, thanks for the update
Message 17 of 31
Ok Have connected. Seems to work fine. Down speed 90, up speed 30 via extender and lan. No drop outs yet, watch this space.
Message 18 of 31
OK thanks, that should work. Could you give it a try and let us know how you get on
grahamh123
Message 19 of 31
uawei 8041w-2.t5/av1/c1
Message 20 of 31
What is the make and model number of the pre FF router?
