always a problem with the line
on 20-03-2023 04:34 PM
Message 31 of 31
So internet is really slow today - I am on fibre150 data only. When I run a speed test it gives me 38Mb down and 30Mb up to my device. Doesn't show a speed to my hub. When I do a line test it ALWAYS comes back with "we think you have a problem with your line" and then it says "we are working on it, please check back in a couple of day" When I check back in a couple of days the fault has been cleared - no message. A few days later it does it again. Last time I spent some time on the phone and was sent a new LAN cable, no difference. Starting to wonder why I went for fibre 150 as it seems no better.
Labels:
- Labels:
Connection
Speed
Stability
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
30 REPLIES 30
on 27-04-2023 04:09 PM
Message 21 of 31
Just run another line test and it still shows the fault being investigated. Can I use the old (pre FF) router?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-04-2023 04:07 PM
Message 22 of 31
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-04-2023 02:26 PM
Message 23 of 31
Hi Graham,
Line test is still passing. Which router do you have? Have you tested with a different router?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-04-2023 01:30 PM
Message 24 of 31
Hi Chris,
Ok, you confirm what I already said. I check the line - it finds a snag and tells me to check again in a couple of days. When I do there's no follow up info so I assume its all been fixed. Next day or so it does it again with same messages and same result. You say you checked the line a couple of times and there's no fault apparent. Today I cannot stream to alexa, it drops out repeated for up to 30 seconds at a time. Same with the tv. Cannot see anything on my PC as its connected via lan. Cannot see any changes to lights on the box on the wall or the router. About ready to give up on Talktalk. If I can't get a reliable service then I shall have to leave. Just run a line test and it finds a fault (27/04/2023), check back in a couple of days etc etc. No mention of the same message on the 24th. Need to upgrade this to a formal complaint.
regards
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 26-04-2023 07:45 AM
Message 25 of 31
I don't know why it's showing a fault, I've run a couple of line tests and they are passing. If possible the next time the connection drops could you check the router and ONT to see if the lights have changed
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-04-2023 04:02 PM
Message 26 of 31
Hi Chris,
couldn't say. It drops out for a few seconds, a minute at the most and I'm nowhere near the ont at the time. But......why is it that when I do a connection test there is always a fault on the line; then ' come back and check in a couple of days' message and when I go back in a day or so the fault log is gone - till next time.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-04-2023 02:51 PM
Message 27 of 31
Hi Graham,
Do the lights change on the ONT or router when the connection drops?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-04-2023 01:36 PM
Message 28 of 31
Speed is not bad. Cannot connect directly as I run a desktop from the study via an extender and lan. The problem is with the wifi. Don't notice any dropouts on my desktop via the lan. Have tried shutting down the router for 30 mins and rebooting it - no difference. As I said when I run a connection check it invariably comes up with a fault on the line (as it is now) and the message check again in a few days time. really can't be doing with it.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-04-2023 01:17 PM
Message 29 of 31
Ok so I am back to - there is a fault on your line (dated yesterday) and 'we are trying to fix it'( how exactly and what is the problem with the line?). Since then the internet(wifi) drops out every few seconds or every minute. Can't listen to the radio (Alexa) or stream TV as it continually comes up with check your internet and freezes.
Why is that talktalk cannot provide me with a reliable service? If this is the case then can I terminate my contract without penalty? After all I am paying for a service which talktalk are not providing.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-03-2023 06:58 AM
Message 30 of 31
I'm sorry to hear this. Can I just confirm, is the speed also low if you connect wired? What speeds are you seeing if you connect directly at the ONT with the router removed?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- « Previous
- 1
- 2
- Next »
