2.4GHZ DEVICES KEEP DISCONNECTING
akhilsete
Message 3 of 3
Hi, I have a couple of devices connected to my router that need 2.4Ghz and can’t use 5Ghz. These devices keep disconnecting from the router and won’t reconnect? Do I need a new router? Can I purchase a generic one to connect to TalkTalk?
Message 1 of 3
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Message 2 of 3
Hi akhilsete
Please can you update your Community Profile to include your name and TalkTalk landline number, we can then look into this further.
