Access Denied
Jayb1000
Message 5 of 5
Hi, today I noticed my partner was unable to check her online banking and airline websites, I later in the day tried accessing the Steam store and was met with a black screen. I decided to check the Steam website to end up with "
Access Denied
You don't have permission to access "http://store.steampowered.com/" on this server.
Reference #18.4a4bdd58.1661203188.77080dca"
This has come out of nowhere and is limiting access to a lot of apps/sites i use.
I have already checked for any safe search options and they're all off.
Hopefully someone can help.
4 REPLIES 4
Message 1 of 5
Can you add the home phone number to your 'Community Profile' so I can check your connection.
Message 2 of 5
I have already tried doing this, nothing changed.
Message 3 of 5
Have you also tried powering down the router for a full 30 minutes as this will clear the current session?
Gondola
Message 4 of 5
Hi Jayb1000
Clear your browser cache / cookies / history.
Either disable the VPN you're using or set up the VPN to use a UK host server.
Disable any Tracking cookie blockers / ad blockers until you're sure the website will permit access using ad blocking.
