4 hours ago
I cannot access National Lottery or any gambling sites since this morning, everything was OK last night and no changes have been made. I do not have parental controls on as no children in the house.
3 hours ago
Thanks for confirming.
This has been raised to support staff as we are seeing a few other posts on this topic.
3 hours ago
Talk talk that should have read!
3 hours ago
I just have a talk talking router
4 hours ago
Which router are you using?
I ask as I saw a similar issue with someone who is using an Eero.
I posted the following for them to check but have not had a response. If you have an Eero, could you try and advise please? If its not an Eero can you confirm the model so support staff can look into further. Tjank you.
do you have advanced security set to on under Network Controls?
If so does turning this off make any difference? If so you could turn it back on and maybe add the sites you wish to the Allow Sites list.
I don't know if this will help but may be something to try.
