Advice on how to utilise my old Hub 2 router as an extender
TWH0857
Private Message TalkTalk PLUS
Message 5 of 5
Just been upgraded to full fibre and have received a new Hub 3 so I have the Hub 2 as the spare and was wondering if it can be repurposed as an "extender, using TP Link plug ins and cables, as the signal at the back of the house isn't that good?????
4 REPLIES 4
Message 1 of 5
Thank you for the support @fr8ys
Message 2 of 5
Pleased you found the answer and got it working.
TWH0857
Message 3 of 5
Well, after a little research I now have the HUB 2 configured as an access point and connected to the Fibre network!!!!
Thanks @fr8ys for the link which led me to a youtube video.👍
Message 4 of 5
There's quite a bit of advice available by doing a google search.
Try this
https://www.google.com/search?q=using+old+router+ss+an+extender&oq=using+old+router+ss+an+extender&s...
