Broadband connection dropping
curtisrm
Message 13 of 13
Hi, my broadband connection drops frequently; the LED on the router will suddenly start flashing amber. It sometimes reconnects itself, other times I have to restart the router to reconnect. This happens as often as 3-4 times a day. I am also intermittently getting very slow speeds. I have not changed my configuration for two years and have never had either of these problems before.
If I run the connection test, it says "We suspect an issue with your broadband", and it asks me to enter my mobile number. I have done this several times, and I always get a message from talk talk saying my connection is fine.
I have also gone through the suggestions in the "Fix a dropping broadband connection" help section, but nothing seemed to resolve the issue.
12 REPLIES 12
Chris-TalkTalk
Message 1 of 13
Hi Curtis,
Thanks for the PM, I've booked the engineer for tomorrow AM (September 14 2022, 8am-1pm) - please let us know how you get on
Message 2 of 13
Hi curtisrm
I'm just sending you a Private Message to confirm some details so we can arrange the engineer visit.
curtisrm
Message 3 of 13
Yes, I replaced the cables and the microfilter.
Message 4 of 13
Thanks for confirming. I've re-run the line test now which is still detecting a potential fault. Did you also replace the cables and microfilter as the next step would be to arrange an engineer visit if the connection is still unstable?
curtisrm
Message 5 of 13
The new router has arrived and is now connected, so you can go ahead an run another line test.
Thanks!
Message 6 of 13
Hi curtisrm
No problem 🙂
Let us know once the new router is connected and we can run another line test.
curtisrm
Message 7 of 13
Sure, that would be great, thanks!
Message 8 of 13
Hi curtisrm
Would you like me to send a router for testing so we can rule this out?
curtisrm
Message 9 of 13
Thank you for checking Debbie. No, I have not tested with another router, I do not have another router to test with.
Message 10 of 13
Hi curtisrm
I've completed a line test which has detected a potential fault towards the property and Openreach are requesting that we arrange an engineer visit.
Have you recently tested with a different router at the test socket?
Message 11 of 13
i've added the info
Message 12 of 13
Hi curtisrm
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
