Can a DG8041W-2.T5 be set to WPA3
Montmist59
Message 2 of 2
Our iPhone is telling us to set our router to WPA3 as WPA2 is considered to be 'weak security' and as such has switched to using the 4G which is burning through data ( wife's phone BTW ).
So can it be set to WPA3 and if so how can we do it.
I appreciate that the router is reasonably old by modern standards .
TIA
1 REPLY 1
Message 1 of 2
No it can't but don't worry about it. iPhones are fussy with security alerts. As long as you have WPA2 AES set then you will be fine.
