Company VPN Connection issues Folloing firmware upgrade
StaceyMaude
Message 9 of 9
I'm Having issues with my VPN at home, it has been working fine until 23/03/2022 where it would appear that ive had a firmware update to SG4K100130 and now it wont connect
My IT department have investigated and confirmed that they have had similar reports for other users with TalkTalk as the provider, and confirmed that they resolved the issue by updating the Firmware to another version and is supported by a number of Community threads including one by one of our users
https://community.talktalk.co.uk/t5/broadband/unable-to-access-company-VPN/td-p/2854424
ive spent several hours on the phone to customer support who continue to push me towards port forwarding, have sent me a new router (of the same Sagecom type) and that Firmware updates are automatic with now way to manually update (Despite @Debbie-TalkTalk on the support team managing it on another post) and now suggesting another router (wifi Hub Black) - i cant afford to wait another few days to 'maybe' fix the issue that way
the suggested Firmware update that fixed this issue was SG4K10002828t and i need someone to assist me in applying this or equivalent
the  VPN Type is PPTP and could well be what's been blocked as have this across other providers (Virgin, BT) in the past
stacey hudson
8 REPLIES 8
Message 1 of 9
Just checking in to see if the replacement router has arrived?
Message 2 of 9
Hi Stacey
I'm now unable to connect to your router, apologies for this.
The Huawei WIFI hub is already on its way and you should receive this within the next 24-48hrs.
StaceyMaude
Message 3 of 9
Debbie please can you contact me? i am no further forward
stacey hudson
Message 4 of 9
Hi Stacey
Message 5 of 9
Message 6 of 9
Hi Stacey
Just to confirm, you haven't rebooted the router have you?
The firmware is still updating at the moment but we need the router to be left switched on.
StaceyMaude
Message 7 of 9
Yes this is fine, will log back in and check  / confirm  when its come back online
stacey hudson
Message 8 of 9
Hi Stacey
Apologies for this.
I can try the firmware update now.  Will this be ok? (the router will reboot)
