on 20-03-2022 04:56 PM
Hi there just forked out £80 for the WiFi extender kit which on its own works well, but for the life of me I can't pair my old DHP-300AV power line adapters to the new DHP-P610AV power line transmitter.
Could somebody tell me if this is possible or not.
Thanks in advance.
on 31-03-2022 08:51 AM
Just checking in to see how you are getting on?
Thanks 🙂
on 21-03-2022 08:16 PM
Its a Sagemcom Fast 5364.
Will give it a go trying to set up the WiFi adapter and the new transmitter as a separate pairing using another Lan port.
on 21-03-2022 01:25 PM
I assume then that the WiFi hub is the Huawei DG8041W router?
Yes they should all work OK like that.
on 21-03-2022 01:02 PM
Hi Keith thank you for taking the time to look at this for me.
My Router is the newer Talktalk Wifi hub.
You will have to forgive me I drive a Tractor for a living but if I have this right leave the three Older power line adapters as they are one to the Router, one to the TV and one to a Desktop Pc.
Then plug the new Transmitter into a spare Lan port on the Router which is paired to the WiFi extender. With both sets sharing the same wiring? or would one of them need to be on a dedicated Earthnet cable ?
on 21-03-2022 09:51 AM
Hi @Sean1969
@Anonymous has asked me to help you with these PLAs.
I have never seen any instructions on how to do this & not knowing the spec of the older DHP-300AV, it may be the case that connecting them together reduces the performance of the newer 610 to that of the 300.
I would never recommend it anyway, as you would be creating a bottleneck at the network connector end, as there is only this one connector to the router's LAN port. You do not specify which make/model of router that you have & so this could be at only 100Mbps. I would always keep them as two separate sets, so it uses two LAN ports on the router.
on 21-03-2022 08:10 AM
