on 11-12-2024 08:32 PM
I have been telling you for two weeks now about broadband not recording I pay for this service and keeps freezing .what are you doing about it I have heard nothing very rude .I was supposed to receive a WiFi box I can take from house to house with me .also complained I stayed in all day on it some time ago .now do I have to change provider or am I going to hear about this getting dealt with .
on 12-12-2024 07:10 AM
Hi Woody23,
Could you explain exactly what the problem is and can you update your profile as fr8ys as requested.
on 11-12-2024 10:43 PM
I'm sorry but support staff will require clarification of your issues and what steps have been taken to rectify this.
Broadband does not record. Are you perhaps referring to your TV box? If so which box do you have?
I'm assuming its on older recordable YouView box. Unfortunately these are approaching end of life and cannot be replaced with like for like boxes.
If its a YouView box, have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but it's the last option to rescue the box.
You mention that you were to be sent a Wi-Fi that you could take from house to house. This seems strange as equipment is not designed to be portable. The new TV Hub if Wi-Fi enabled but not recordable.
If you can clarify that my assumptions are correct, and that you have tried the maintenance resets it will be of help.
You are in the staff's queue for a response though.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
