Connection dropped to 2Mbps
intosly0
Message 4 of 4
Good afternoon all,
since last night i have had a dropped connection from 65 to 1.5-2 Mbps ( upload is around 5Mbps )
I have restarted my router and performed a hard power pull and replug, but the connection remains slow.
I have tried to check for outages / planned maintenance in my area but cannot find anything.
Running a line test on the talktalk website also results in the "There was a technically issue" error
Not sure how to progress from here, i cannot test voice as we do not use a landline!
Thanks all,
-Gav
3 REPLIES 3
Message 1 of 4
Hi Gav
Do you still need help with this?
Message 2 of 4
Hi Gav
Please can you add your TalkTalk landline number to your Community Profile, I can then check the connection stats and run a line test.
If you are unsure of your landline number then if you log into My Account it will show there.
martswain
Message 3 of 4
If the line is faulty then it can drag down broadband performance.
Suggest you borrow a handset and test.
Live chat is an option or call 0345 172 0088
Staff will not be back until Monday unless someone is doing weekend overtime.
