on 03-03-2022 09:55 PM
Every now and then I lose internet its only briefly but can be a little annoying.
I added some logs in screenshot form I attached to this post.
Another other information need just ask.
TalkTalk Wi-Fi Hub
version SG4K100130
| SG4K100130 |
Cheers
on 07-03-2022 06:46 AM
Hi wpa_2
How has the connection been since you connected the replacement router?
on 06-03-2022 02:53 PM
I shall defo do that thank you for the tip. 🙂
on 06-03-2022 01:09 PM
When you do return the old router keep a record of the tracking number and a certificate of posting, @wpa_2.
The recording and processing of returned routers often get delayed at Talktalk's end, resulting in them sending out a bill for £50....
So hang onto the paperwork!
on 06-03-2022 12:33 PM
Shall I return the old return using the prepaid envelope, This router seems a lot better already I like the advanced settings on the new one.
I shall monitor my internet over next couple of days and report back.
Cheers
on 06-03-2022 11:30 AM
No worries.
on 06-03-2022 11:29 AM
You are correct it is different, I shall test it now then thank you very much.
on 06-03-2022 11:26 AM
The Huawei looks superficially similar to the Sagemecom, but has an all black fascia as opposed to bronze holes, so have you in fact got the same model?
on 06-03-2022 11:20 AM
Received router have not tested it yesterday but just to say its the same as what I already have so is it still worth trying?>
Cheers
on 04-03-2022 07:35 AM
Hi wpa_2
Thanks for you reply.
The Huawei WIFI hub is on its way, please allow 24-48hrs for this to arrive.
on 04-03-2022 07:28 AM
If you think that would solve the issues then yes I'm willing to give it ago.
thanks for the swift reply.
on 04-03-2022 07:27 AM
Hi wpa_2
The firmware your router currently has should resolve the reported DNS issues.
I've completed a line test which hasn't detected any faults but I can see some re connections.
Would you like me to send a Huawei WIFI hub to see how the connection compares?
