Dating apps blocked on wifi, works otherwise everywhere
sixtimeshypocrite
Message 6 of 6
Hi.. it seems like dating apps are blocked when connected to my wifi. Tinder shows network error, and Bumble is also very very slow. But when i switch to mobile internet or even other WiFi networks both apps work flawlessly. This is so weird and inconvenient.
I checked my account settings and no homesafe settings are enabled.
5 REPLIES 5
Message 1 of 6
@Stacey2308
Have you checked the advice posted earlier and tried those suggestions? Otherwise, if you need further help with this, please start your own topic
Stacey2308
Message 2 of 6
Hi, did you get a resolution to this? I'm having the same issues
Message 3 of 6
Ok could you turn off the router for an hour or more overnight then retest please.
Ady
sixtimeshypocrite
Message 4 of 6
Tried switching the homesafe and security options on and off again, but it dint work. Honestly all other content seems to working fine, including adult content. So this seems rather odd.
Ady-TalkTalk
Message 5 of 6
Hi sixtimeshypocrite, it's worth trying a quick reboot of HomeSafe by turning it off and on again.
Ady
