Home Phone
Callsafe not populating approved callers with calling circle numbers automatically when switched on
jon1967
Message 10 of 10
does this happen overnight ? Otherwise how does it work please?
I dont want to add them all manually it will take forever and i dont want to turn it in and have all calls blocked meantime...
Tia
9 REPLIES 9
Message 1 of 10
Yep turned off following morning as didnt do what anybody says!
Is there no technical guide to this functionality that your side can look at?
You seem to say it will just fill up at some point
The screen shots seem to imply that you can selectively import  numbers but dont tell you how (like somebody has forgotten to build the functionality)
So confusing . I feel im a beta tester for talktalk again. Maybe i can get paid ?!
Best regards
Message 2 of 10
Message 3 of 10
Ok finally got around to this. Turned on last night . Nothing this morning again in approved list
Message 4 of 10
Well ill turn it off now and turn it on overnight if your sure . I dont want calls blocked meantime
I do feel the instructions are not clear at all
Thx/regards
Thx
Message 5 of 10
Message 6 of 10
Ok turned on and says on
Cant see any numbers in approved
Get this cryptic message
Numbers in your Approved/Blocked list may also be imported from your Last Call Barring, Frequently Called Numbers or Calling Circle.
But no way of doing it
Message 7 of 10
HI jon1967
Numbers will transfer over to Callsafe, but at the moment it is not showing as active on your account.
If you activated it via My Account did the confirmation pop up show?
jon1967
Message 8 of 10
Manage CallSafe Status
By switching on this feature, unknown callers will be asked to say their name and press # before your home phone rings, meaning you get to choose whether to take the call or not.
If you wish to turn CallSafe on, the numbers you have barred from Last Call Barring will be imported over to your blocked list. Numbers in your Calling Circle or Frequently Called numbers will also be imported to your approved list.
Gliwmaeden2
Message 9 of 10
You do need to add numbers manually whenever Callsafe has been switched off - they are not saved in the system, even if you have safe numbers saved in your phone.
For full instructions:
https://community.talktalk.co.uk/t5/Articles/How-to-use-CallSafe/ta-p/2204789
