on 25-09-2025 11:11 AM
Just in the last few days no longer able to download Demand on Sky, disconnected router and sky box to no avail. Virtual assistant no help.
on 26-09-2025 12:07 PM
Thank you for the feedback @steve_x99, well on our end we've not been made of any issue with our DNS servers, so I'd assume it was not a fault on our side.
Kanya
26-09-2025 10:16 AM - edited 26-09-2025 10:29 AM
Thanks, I've just checked and it is working ok now.
On the Sky forums, Sky say it is fixed.
There is some confusion as to whether it was a Sky fault or TalkTalk fault.
on 26-09-2025 08:21 AM
Hey there, @Fedup35. Are you still having the same issue? and @steve_x99 I'd advise you start you own thread as well so that we may also assist you.
Kanya
on 25-09-2025 01:07 PM
The DNS server that you have changed your DNS setting to (on a recommendation by another user) is the Cloudflare secondary DNS server (1001).
It is probably not the case that there is a fault requiring any investigation. Instead, it's likely just down to the TalkTalk DNS server update frequency, i.e. the frequency at which the DNS server queries the authoritative DNS server, instead of continuing to use a cached DNS record.
Google and Clouldflare DNS servers are known to update frequently, hence people use them in preference to their ISP's DNS servers.
on 25-09-2025 12:09 PM
I have also had this problem since Tuesday.
This is reported by a lot of people on the Sky community forums.
There appears to be a problem with the TalKTalk DNS.
As suggested on the sky forum I have changed the DNS IP address in my Sky box which fixed it for me currently.
To change the DNS in my Sky+HD box it is...
Press Services. Go to Settings, Network. Press Down. Press green button for Manual IP configuration.
Press Down to go to DNS. Type 1 Press right Type 0 press right Type 0 press right type 1
Then Save
Are TalkTalk investigating?
