Desktop computer will not connect to the wifi hib.
c_wakeraley
Message 29 of 29
My home desktop computer will not connect to the talk talk WiFi hub.
What I have tried:
On computer:
- reset WiFi adapter.
- reset Winsock and iP stacks.
- uninstall and reinstall drivers.
- bought a separate WiFi dongle adapter and try to connect, will not connect saying ' cannot connect to network '
- try to connect PC one metre to hub, won't connect.
- Install fresh copy of Windows 11, will not connect.
- connected computer via Lan, computer can Access Internet, take cable out and try to connect via WiFi, it will not connect.
- Pc will connect to other WiFi networks, just not the talk talk WiFi hub.
On hub:
Reset WiFi hub, won't connect.
The lights on the hub is solid white.
28 REPLIES 28
Message 21 of 29
Your WiFi password for the network name ending in 83 is taking too long to be exchanged with the router. It uses the WiFi Network adapter Realtek 8811CU which is connected via USB. I assume this is the adapter that you are trying to connect with?
Have you tried "forgetting" the network & then reconnecting to it?
Message 22 of 29
Hi Keith,
Apologies for that, i found the files you requested.
thank you again.
Message 23 of 29
Hi @c_wakeraley
Your zip file does not contain the correct files. In the folder:-
C:\ProgramData\Microsoft\Windows\WlanReport
This is a hidden folder, but is easy to view by pasting the above folder into the Run box in Windows.
You should find at least four files like this example:-
files to zipfiles to zip
Please can you try again?
Message 24 of 29
Hi Keith,
Thank you for trying to help me.
here is the file report you requested.
regards.
Message 25 of 29
Hi @c_wakeraley
@Anonymous has asked me to help you. Please open a command prompt window by going to:-
Start > Accessories > Command Prompt
Alternatively, click the Window Icon & type in the search box:-
cmd
in the search box next to it. This should find the "Command Prompt" from there, but right click it & select run as administrator. In there, enter the command:-
netsh wlan show wlanreport
Followed by Enter. Then wait for it to finish.
Then go to the folder:-
Zip up the files in that folder & attach them to your reply.
Message 26 of 29
Hi again,
Thanks for confirming. @KeithFrench - Would you be able to offer any advice on this please?
In regards to the latency, what speeds are you seeing if you run a speed test please?
c_wakeraley
Message 27 of 29
Hi Michelle,
I can confirm that, other divises can connect, some however have Latency issues, the amazon fire stick has Latency issues and my computer will not connect to the WiFi hub what ever I do.
Message 28 of 29
Good morning,
I'm sorry to hear this. Can I just confirm, do your other devices connect ok, just not this PC?
