Devices unable to connect to wifi
EvansI
Message 22 of 22
Over the last week my talktalk router seems to have developed a fault where devices disconnect from wifi and are unable to reconnect. The only way to resolve the issue is to restart the router, however after a few hours the devices are again kicked off and can't reconnect.
21 REPLIES 21
Message 21 of 22
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
