on 13-03-2024 04:09 PM
Like many homes now I find the increasing amount of devices I require is struggling on the current plan (Fiber 65) which is the maximum speed I can get due to no fiber to the property.
My question is
If I was to purchase an Amazon eero6 router would it help WIFI connections to around 30 devices ???
on 14-03-2024 11:08 AM
Is it all OK then?
on 13-03-2024 04:52 PM
Hi, just ran a speed test :-
Around 15 to 20 devices normal use
3 devices listed with connection issues
John.
on 13-03-2024 04:38 PM
Hi Keith, thank you for the response, the router is a Sagemcom 50001
John.
on 13-03-2024 04:32 PM
What speed do you usually get wired ?
Do you notice Wi-Fi dead spots or slower areas in certain parts of the home ?
How many devices do you usually have connected on average at any one time ?
on 13-03-2024 04:21 PM
If you think that you have WiFi issues just throwing money at it, is unlikely to solve the issue. Are all the devices being used at the same time? What is the actual download speed you are getting at the router? If this is a WiFi Hub of one sort or another, log into it and see the speeds quoted in the initial dashboard area.
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
