Full fibre activation
Kincavel
Message 30 of 30
Installation of my full fibre upgrade has just been completed. Before leaving, the engineer informed me that it could take up to twenty-four hours to activate so, for now, I still have BOTH the ONT and my landline connected to my router.
Will I receive any notification of activation, or will I have to check it via trial-and-error disconnection of my landline from my router?
Also, once full fibre becomes active, does data transmission via my landline cease? If so, I infer that I could then remove the 'splitters' from my landline as it would then revert to being a dedicated telephone line. Is that correct?
Kevin Snowdon
29 REPLIES 29
Kincavel
Message 21 of 30
In the absence of any meaningful response, I've experimented with my connections (as I probably should have done from the start), and can now report that...
  • With the ethernet cable from the ONT removed from my router's WAN port, I have internet access (i.e. via my landline, as before).
  • With the ONT connection restored, and my landline cable removed from my router's broadband port, I have NO internet access.
So the obvious conclusion is that my fibre connection has still to be activated more than forty-eight hours after installation, which I shall now report as a fault.
Once the fault has been fixed, I shall repeat the above actions, which will hopefully go some way towards answering my original queries for myself.
Kevin Snowdon
Kincavel
Message 22 of 30
Sorry, but I don't understand the need for a PM. My queries seem to me to be perfectly simple, basic, and straightforward, namely...
I now have a physical full-fibre broadband connection, but I don't know whether or not it has actually been activated yet. So...
Will I receive any form of notification that full-fibre is active?
...or will I just have to try repeatedly disconnecting my landline from my router's broadband port to see if I still have internet access (in which case, it could only be a fibre connection via the WAN port)?
Once full fibre is active, will data transmission via my landline continue?
...and if it does, would there be any adverse impact if my landline were to remain connected to my router, thereby duplicating the signal source?
...or if it doesn't, can I then remove the splitters from my landline (which would have then become a dedicated phone line once more, making the splitters redundant)?
There is no personal data involved here, so why can't the discussion simply continue in the forum?
For the record, I still have four green lights on the ONT, and can still access the internet... I just don't know by what means!
Kevin Snowdon
Message 23 of 30
Hi Kincavel
Ok, I'm just sending you a Private Message to confirm some details so we can look into this further.
Kincavel
Message 24 of 30
There may be some confusion here, depending upon when the last update occurred. The installation actually took place over two days. On day one, only the internal and external boxes were installed. The cable connection to the external box couldn't be done because the metal pole couldn't be climbed... and a cherry-picker wasn't available. I'm pretty sure this was logged at the time, and might be the last entry.
The engineers turned up with a cherry-picker first thing the following morning and completed the installation... hence my queries re activation and any subsequent action I need to take.
Kevin Snowdon
Message 25 of 30
Thanks for confirming. I can see that this has been raised for investigation and the latest update is that a fault has been detected at the pole and that a cherry picker is required. We will re-check again on Monday for any additional updates.
Kincavel
Message 26 of 30
There is a WPS button, plus ports for broadband, ethernet (x4), and WAN. I don't see anything I would recognise as a voice port... or a model number. It is a Sagecom router (don't know if that helps).
Kevin Snowdon
Message 27 of 30
Can I just confirm, does the router have a voice port on the back? The model number will be on the back of the router (we have 2 different wifi hubs)
Kincavel
Message 28 of 30
There are four green lights on the ONT, and I'm using a TalkTalk wifi hub.
Kevin Snowdon
Message 29 of 30
What lights are on the ONT at the moment? Which router are you using (make and model)
