Having to restart router
Andy31
Message 10 of 10
Hi.
I often find that our download speed has dropped from our usual 60 Msps to 5 Msps or lower. Restarting the router (turning of and back on) cures it. It affects all our connected devices, even the main PC which is on a wired connection.
Looking at the router's log, I see many warnings like : Intrusion -> src=89.248.165.65 DST=78.144.220.150 LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=15267 PROTO=TCP SPT=49347 DPT=3393 WINDO
and 'port scan attack'.  Any idea what is going on? I have attached a copy of the syslog.
Andy.
9 REPLIES 9
Message 1 of 10
Hi Andy
I have sent you a Private Message with a link to a short survey for the Community.
Debbie 🙂
Message 2 of 10
Andy31
Message 3 of 10
Old 633 router and PSU now on its way back to you. Thanks for your efforts.
Andy
Message 4 of 10
Hi Andy,
Glad to hear the new router has resolved the problem
Yes, could you send the old router back. Would you like me to send a returns bag (you don't need to put the router in the box)?
Andy31
Message 5 of 10
Debbie, the new router arrived on Saturday and it cured the problem(s). Connection speed is now a solid 68 Msps and there has been no need for any restarts. Wifi coverage is also much better. So many thanks for your prompt action.
What happens now, do you want the old HG633 back? If so, the plug-in power supply won't fit in the box, and it doesn't dissemble like the new one.
Andy
Message 6 of 10
Hi Andy
Thanks for the Private Message 🙂
Message 7 of 10
Hi Andy
Please can you send me a Private Message to confirm the name on the account, I can then send the replacement router.
Message 8 of 10
Sorry Debbie, I'm having trouble replying for some reason. Yes, please, a new router would be a good idea. Thanks.
Message 9 of 10
Hi Andy
Would you like me to send a replacement router for testing to see how the connection compares?
