on 07-12-2021 07:00 PM
I have fibre 65 and the speed to the router is around 65Mbs and from the router to the devices is around 54Mbs but as the day goes on it slows down usually around teatime, today it slowed to 0.1Mbs. After switching the router off and on the speed goes back to 54Mbs, this is happening everyday so I am thinking is there a problem with the router.
on 14-12-2021 10:08 AM
Hi Shane
The line test is clear but it does show - Regular Interference Observed Daily.
Is the router located near to any devices that could cause any interference?
on 14-12-2021 10:01 AM
Hi Debbie
Tried the new router and it is worst than the last one, when fitted I was getting 64MBps to the router and 54 to devices yesterday.
Came on line this morning and I was getting 1.4Mb to devices wired and wireless, had to restart router and was getting 64Mb to router and 19Mb to devices. Tried another test and it dropped to 1.4Mb, just done another one and it is at 18Mb.
I will move the router to see If there is a problem with the position, there is only my wife and me so we only have a couple of devices connected so I am not sure why the speed keeps slowing down, I feel the more we use the net the slower it gets until it stops.
on 13-12-2021 06:29 AM
Hi Shane
No problem, please let us know how you get on.
Debbie 🙂
on 12-12-2021 03:29 PM
Hi Debbie
Thanks for the router, I have not had a chance to try as I have been away from home.
I will try it tomorrow and tell you the results
Thanks Shane
on 08-12-2021 06:53 AM
Hi Sticky1245
I have ordered you a replacement router for testing, please allow 24-48hrs for this to arrive.
on 07-12-2021 10:22 PM
Interesting, I've had the same sort of issue with the DG8041W in the past, the staff here should be able to advise tomorrow, and if they think necessary they may suggest sending you a different make of router.
on 07-12-2021 09:20 PM
I have updated my profile and my router is a Huawei DG8041W.
on 07-12-2021 07:42 PM
Hi @Sticky1245,
What model of router do you have ?
