Helium miner, port forwarding
Kentguy
Message 2 of 2
Hi I've got a Nebra Helium miner and attempting to open port 44158 which I understand is blocked or relayed on some talktalk devices. Attempted to speak to Talktalk help but of course, totally useless. Would welcome any advice at all on anyone who might have tried similar.
1 REPLY 1
Message 1 of 2
This will port forward absolutely fine through TalkTalk routers, providing that you add the appropriate port forwarding rule. Please can you tell me which make/model of TalkTalk router you have and include a screenshot of the PF rule that you have tried, so I can check it for you?
