Port Forwarding 44158 to support Helium Miner
DamKan
Message 4 of 4
Hi @KeithFrench ,
Can you please help me, I have an issue with port forwarding. I followed what you have put on your screenshot for another post related to port forwarding 44158. But I am getting the message as on the screen shots below. I do not know what I am doing wrong. I am not that tech savvy but trying to learn things as I run into them.
I just received my miner and was trying to set it us when I ran into few problems and this is one of them. Your help will be much appreciated. Thanks
3 REPLIES 3
Message 1 of 4
You will need to contact the manufacturer of this device for that information.
Message 2 of 4
Hi @KeithFrench ,
Thanks for the advice, i re-set the router to factory default and it worked. Now I need to figure out why I am getting the below message when I am setting up the bobcat helium miner:
hotspot miner is waiting to start, please try again in a few minutes”
if you know where I would be able to get advise on that please let me know. Once again thanks for your help.
Message 3 of 4
HI @DamKan
There should be no problem forwarding this port at all, I have tested it many times for people using this router & never once seen this error with this port. Please can you try a factory default of the router's configuration & let me know the outcome?
