How to remotely reset router
Bettyga
Message 3 of 3
My router’s wifi capability keeps failing requiring a full reset (pin in small hole)..if however I’m away from home, how can I reset my router remotely ?
ertriad
Chris-TalkTalk
Message 1 of 3
Hi Bettyga,
I can see that Keith has kindly offered to assist you with this. Can you also please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
It cannot be reset remotely. Have you looked into why it needs resetting, it is probably down to WiFi interference.
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
