Huawei DG8041 Router Trouble
MichaelW4
Message 13 of 13
Good Morning,
I've been having WiFi trouble for around two weeks. I can connect devices to the router but the speed drops off from around 65mbps to sub 2mbs after a few minutes up to a couple of hours after resetting the router, which we're doing several times a day. I've tried doing a factory reset, and also had a chat with a technician a week ago and went through the diagnostics. We didn't find a fault on the line and they said they would monitor it for 24 hours. They also updated the router software. They said it would be kept on record if you need the details.
I was wondering if I could try a test router as this seems to be the issue.
Thank you,
Michael
12 REPLIES 12
Message 1 of 13
Hi Michael
Thanks for your reply.  If you do experience any further issues then please let us know.
Message 2 of 13
Hi Debbie,
The issue has been resolved for now thank you. The engineer mentioned we'd need to upgrade to fiber to the property in the future.
Thank you,
Michael
Message 3 of 13
Message 4 of 13
Hi Michael
How are you getting on, has the engineer been out?
Message 5 of 13
Hi Michael
Please let us know how you get on following the engineer visit.
Message 6 of 13
Hi Debbie,
Thanks I'll send it back. It's 55Mbps to the router, and the guaranteed is 59Mbps. I've just had a message to say an Openreach engineer will be coming out to take a look.
Thank you for all of your help!
Michael.
Message 7 of 13
Hi Michael
Thanks for keeping us updated. Just to confirm, what speed are you receiving when running a speed test?
Yes please can you return the old router using the pre paid returns bag.
Message 8 of 13
Good Morning Michelle,
The new router seems to be working fine so far, although the broadband speed is slightly less than the guaranteed speed at the moment.
Should I post the old router back now?
Thanks again,
Michael
Message 9 of 13
How are you getting on?
Message 10 of 13
Great, thank you 🙂
MichaelW4
Message 11 of 13
Hi Debbie,
I will do, thank you.
Michael.
Message 12 of 13
Hi Michael
Thanks for creating a new thread.
I have ordered a replacement router, please allow 24-48hrs for this to arrive.
Thanks again.
