Intermittent Broadband
WELLA182
Message 17 of 17
Hi, I’m having issues with my broadband dropping out and slow connection during the evenings. The connection is fine during the day. I’ve contacted the online chat and spoke with support but no fixes have worked. Could someone check my line please? Thanks Adam.
16 REPLIES 16
Message 1 of 17
Hi Adam
That's great news, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
WELLA182
Message 2 of 17
Morning Debbie, new router was delivered Wednesday and has fixed the slow evening speeds, the new router looks newer than the one I had. Thanks for the help! Adam.
Message 3 of 17
WELLA182
Message 4 of 17
Hi Debbie, should be delivered today, I'll let you know if it works, thanks.
Message 5 of 17
Hi WELLA182
Message 6 of 17
Hi WELLA182
WELLA182
Message 7 of 17
Morning Debbie, yes please, that would be great, thanks.
Message 8 of 17
Hi WELLA182
The line tests are clear - No faults detected.
Would you like me to send a replacement router for testing?
WELLA182
Message 9 of 17
Yeah, no problem. Previous comment was an update of the issue for the talktalk person.
Message 10 of 17
I did say that the TalkTalk staff on here won't be back until tomorrow.
WELLA182
Message 11 of 17
Thanks Keith, it’s been terrible tonight, Wi-Fi and hardwire. I’ve done a connection test which highlights a possible fault, so I do the 5 minute test, then it says the fault is fixed.
Message 12 of 17
OK, thanks for that, it sounds like the router might be faulty. I have asked one of TalkTalk's support to pick your thread up and see if they agree with me.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
WELLA182
Message 13 of 17
Ethernet and Wi-Fi devices are affected. I’ve started periodically testing the Wi-Fi on my phone and hardwired speed to the fire stick sat on the couch in the same room as the router throughout the evening. Through the day I WFH with a hardwired connection with no speed issues.
Message 14 of 17
Thanks for that, it looks as if the problem is not the broadband itself, but between the router & one or more of your devices. Is this just affecting wireless devices or Ethernet connected ones as well?
WELLA182
Message 15 of 17
Hi Keith, my router is a Huawei-DG8041W. The light remains solid white during the slow and disconnected periods, which are between ~6 PM to 9 PM. We don’t have a phone to plug into the socket. I’ve tried resetting the router on the back of the unit and had the power disconnected Thursday evening after TalkTalk support said they’d changed a setting from their end on my connection. Thanks, Adam.
Message 16 of 17
Which make/model of router do you have & what is the exact status of the light(s) on it when this happens? If you plug a phone into the line, do you hear any noises (you can just press any single number to get rid of the dial tone)?
Anonymous User
