Like many others can't connect to work VPN
Woody_32
Visitor
Message 12 of 12
Like many others, I am having problems connecting to my work VPN on Talktalk. I can connect via a mobile hotspot. I am the only one on Talktalk all other colleagues are with other providers & are having no issues, if that makes a difference. So to me the VPN is fine, the issue is with Talktalk. I have the updated version of the firmware, version SG4K100130 for the Sagemcom Fast 5364 router, which others have mentioned a causing an issue. I've tried a factory reset hasn't worked.
Talktalk support just keep adding teamviewer to a safe list of sites and turning kid safe & scam protection on/off (I have load of email confirmations confirming this). Kept trying to tell them Teamviewer wasn't the problem, connecting to the VPN was & teamviewer isn't a VPN. So got nowhere with them.
Can also see that they have sent some people new Huawei routers which have solved the issue.
11 REPLIES 11
Message 1 of 12
Hi Woody_32
I'm so glad to hear this.
Thanks for letting us know 🙂
Message 2 of 12
Hi Debbie
Just received the Huawei router & the problems with the Sagemcom router not allowing me to connect to the VPN seem to be fixed.
Thank you for your assistance.
Message 3 of 12
Hi Woody_32
No problem, please let us know how you get on.
Message 4 of 12
That's great thank you.
Message 5 of 12
Hi Woody_32
There's no charge for this router.
Message 6 of 12
Just also thought, does this incur a charge? As I'm not paying for something that is not my error.
Message 7 of 12
Hi Woody_32
Message 8 of 12
Yes that would be fine.
Message 9 of 12
Hi Woody_32
Thanks for the additional information. Are you happy for me to send a Huawei hub for testing whilst we investigate the issue with the Sagemcom?
Woody_32
Visitor
Message 10 of 12
Yeah it has been working fine for the last 18 months. Just the last couple of days since I got the update. I'm just using the windows 10 VPN client.
Message 11 of 12
Hi Woody_32
Apologies for this.
Can I just check, did this work ok prior to the FW update?
Which VPN client are you using?
