Modem mode on TalkTalk Wi-Fi Hub 2
rhin1
Message 2 of 2
I'm looking to get a 3rd party router, how do put the TalkTalk Wi-Fi Hub 2 into modem mode? I had a look in the advanced settings and couldn't see anything.
1 REPLY 1
Message 1 of 2
You cannot put it into modem mode. What you can do however, is to connect another router by Ethernet from an Ethernet port on the Hub 2 to a WAN port on the other router. Both routers must crucially be on different subnets though, otherwise, nothing will work at all.
