Multiple Powerline Adaptors
on 25-02-2023 01:29 PM
Message 5 of 5
Hi, I can't find the answer i need regarding powerline adaptors. I'm using the talktalk wifi extenders but I'd like to know if i can use one sender and two receivers. Many thanks
Labels:
- Labels:
Powerline adapters
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
4 REPLIES 4
on 25-02-2023 02:48 PM
Message 1 of 5
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2023 02:32 PM
Message 2 of 5
Just a thought, have you paired you existing plugs?
If you find an extra one does not work, try resetting the existing plugs, as they should just plug and play.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2023 02:18 PM
Message 3 of 5
Thanks, i'll give it a try. Cheers
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 25-02-2023 02:05 PM
Message 4 of 5
Yes you should be able to.
I use TP links myself and have 5 linked around the house.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
