Problems with buffering with new TV hub
Mart49
Visitor
Message 4 of 4
Have recently switched to Fibre 65 from Fibre 35 and a new TV Hub to replace old talktalk box ,had no buffering problems with old set up but have with new one , have buffering problem on TV apps with new TV hub. New Hub connected like the old box to router via powerline adaptors  ,  I used my old box with the the new Fibre 65 and the buffering problem started ,TalkTalk suggested the new Hub instead which I now use but the problem remains . I will say on some of the apps its very intermitant on others its more regular . Any thoughts on the matter  ?
3 REPLIES 3
Message 1 of 4
It may be poor performance of the powerline adapters that was causing the buffering.
Mart49
Visitor
Message 2 of 4
Hi Karl , have tried your solution and apps are working fine , no buffering
Message 3 of 4
The new TV Hub will connect over Wi-Fi.  Have you tried connecting this way instead of using the powerline adapters and see if it gives a better performance.
